Atlantis 1.6.4 seizing up
medion
Post by medion »
Thanks mikespeir, for your responce.
medion wrote:This is very very anoying and has only started since this newest update.
How long is that delay in your Atlantis?
medion
Post by medion »
Hi admin. it's a 3 second delay. Thanks
Medion.
In most cases this delay is unnoticeable because Atlantis tries to load the module with the inflected forms "on idle". But if a 3-second delay per session annoys you so much, you must be a very impatient person. :wink:
Only a minor optimization is possible here. Any next release of Atlantis Word Processor will not automatically load the module with inflected forms if the Power Type is disabled.
medion
Post by medion »
admin wrote:In most cases this delay is unnoticeable because Atlantis tries to load the module with the inflected forms "on idle". But if a 3-second delay per session annoys you so much, you must be a very impatient person. :wink:
I RESENT THIS COMMENT VERY MUCH INDEED. IT IS VERY FOOLISH OF YOU INDEED TO SAY THIS TO A CUSTOMER YOU ARE A VERY FOOLISH MAN INDEED. I WILL POST THIS ON OTHER FORUMS. YOU HAVE LOST A CUSTOMER. AND INDEED A USER OF THIS WORD PROCESSOR. NO DOUBT YOU WILL REMOVE THIS FROM THE FORUM BUT I WILL KEEP POSTING UNTILL OTHERS HAVE READ IT, GOODBYE.
mikespeir
Post by mikespeir »
Well, I get a little delay every now and again, too. I don't think it's ever as long as three seconds. I don't consider it much of a bother. But, sure, if there's a way to fix that without making something else worse, why not?
medion wrote:I RESENT THIS COMMENT VERY MUCH INDEED. IT IS VERY FOOLISH OF YOU INDEED TO SAY THIS TO A CUSTOMER YOU ARE A VERY FOOLISH MAN INDEED. I WILL POST THIS ON OTHER FORUMS. YOU HAVE LOST A CUSTOMER. AND INDEED A USER OF THIS WORD PROCESSOR. NO DOUBT YOU WILL REMOVE THIS FROM THE FORUM BUT I WILL KEEP POSTING UNTILL OTHERS HAVE READ IT, GOODBYE.
I did not know that "impatient" was an offensive word... ?
I never meant to offend you. So I do not understand your reaction. I find it quite strange.
Hi Medion,
Are these delays happening randomly, systematically, or only at the start of each Atlantis session?
Have you tried changing your mouse settings? Updating your mouse driver?
Maybe you could try using a different mouse? You could borrow one for a few hours, and see if your mouse pointer is still misbehaving after a change of mouse.
Things will be improved in any next release of Atlantis. There will be still a delay required to load the English inflected forms. But it will occur only once after each install/upgrade of Atlantis. Thanks for your patience.
