Remember Documents Feature
valin
Post by valin »
Yes, all my other drop-down menus work. Well, guys, I dug up my registration code. It just took me a few tries to remember my password on my .cod file with my registration code. Next I completely uninstalled Atlantis, deleted any remaining Atlantis files and folders on my hard drive after the uninstall, and deleted all references to Atlantis in my registry (I'm running Win98SE). I then reinstalled Atlantis vs. 1.1.2.3. When I opened it for the first time, I was prompted to register and I did. Voila, my drop-down menu for the recent documents now appeared. Can't explain what caused it to disappear before (maybe gamma rays). Who knows? Probably something insignificant. Anyway, I got it back and am happy. Thanks for all the help. It was probably frustrating not being able to duplicate the problem. Thanks again. It's a great program. Keep up the good work. 8)
I forgot to ask you to send your current Atlantis settings.
If you encounter this problem again, please use the "Save Settings to File..." button of the "Tools | Options..." dialog to create the Atlantis.ini file. Then send this Atlantis.ini file and your Atlantis.ats file from the home folder of Atlantis (if any) to comment@rssol.com. This information might help to reproduce the problem.
