Default Zoom
Lambert John
Default Zoom
Post by Lambert John »
Currently, when you open a new document, it defaults to 100% zoom. I'd like my new documents to default to 110% zoom. Is there a way to do that? I looked throughout the forum for this info, but it doesn't seem to have been addressed before. Thanks.
Re: default zooming factor
Hi!
1. The default document template for new documents is “Normal.rtf”. Open “Normal.rtf” using “File | Document Templates…”
2. Press “Ctrl+A” to select all of “Normal.rtf”.
3. Click in the toolbar “Zoom” combo box.
4. Type “110” in (without the quotes).
5. Press “Enter”.
6. Press “Ctrl+S” to save your changes.
7. Press “Ctrl+W” to close “Normal.rtf”.
From then on, any new document that you create will display with a “110” zooming factor.
