Wonderful Atlantis naturally - tiny problem
Shanforest
Post by Shanforest »
Atlantis what would I do without you! Thank you for all the happy years we've been together.
Tiny prob. Recently every tme I type something all the boxes on the status bar keep flashing in a jumpy way. It stops as soon as I click Save but it's very distracting. Hope you can help.
Shan of the Forest
Do you have this flashing when you open ANY document and start typing text, or this problem is specific to some particular document?
Note that a progress bar is displayed within the status bar when Atlantis is performing a bulky operation (for example, when Atlantis is saving a document, or when Atlantis is repaginating a long document). When a progress bar is displayed for a very short period of time, you might notice some flashing on the status bar.
Also as you might know, the status bar of Atlantis 1.6.1.4 (and higher) is customizable. You can choose which bits of information Atlantis will display on the status bar. In addition, the size of individual sections (panels) of the Atlantis status bar is now automatically adjusted by Atlantis on fly when a longer string of text needs to be displayed within a given section of the status bar. Possibly this automatic resizing is what you call "flashing".
