horizontal line
ramza
horizontal line
Post by ramza »
horizontal line please....
not a gif image please
To turn a blank paragraph into a horizontal line, please do the following:
1) choose the Format | Tabs... menu command,
2) click the Add... button,
3) type the desired width of the horizontal line (for example, 6"),
4) OK out of the Tab position dialog,
5) choose the desired leader character at the bottom of the Tabs dialog (dots, hyphens, or underscores),
6) OK out of the Tabs dialog,
7) insert a new tab character in your document by pressing the Tab key.
ramza
oh
Post by ramza »
oh... i see, i was hoping an automatic/pre-made one :(
but actually, its all good... meaning i'm in full control :)
Re: oh
ramza wrote:I was hoping an automatic/pre-made one
Place the attached file in your Clip Library.
Double-click it in the Clip Library to insert a line at the insertion point in the document window.
Of course, you can edit the clip so that the tab length (and style) suits your requirements.
Hope this helps.
Horizontal Line.rtf
(1.58 KiB) Downloaded 1355 times
ramza
Post by ramza »
it insert blanks.... but i see it if i open the attachment (rtf) and i see the line
but if i drag'n'drop it out of the clip library, its all blanks (space)
anyway thanks
That’s strange! This is working on my system, whether I use drag & drop or I double-click the clip item.
Which system units are you using? I am using centimeters. If you are using inches, you could try to recreate a similar clip using a tab stop formatted in inches.
Note that this tab stop (line) can be formatted with a different font color. I used automatic (black) color, but you could use red or any other suitable color.
Hope this helps.
Hi again,
I just thought of something.
How did you add the clip to your Clip Library?
Did you put the downloaded RTF directly in your Clip Library (by default in “C:\Program Files\Atlantis\Clip Library”)?
Or did you open “Horizontal Line.rtf” in Atlantis, then save its contents as a clip item?
If you used the second method, you should be careful to copy the whole of the file contents, including the extra paragraph end mark. Copying this extra paragraph end mark is absolutely essential if you want the clip to work as expected. Please use Ctrl+A to select the whole of the file contents including the extra paragraph end mark, then save the selection as a clip item.
Hope this helps.
ramza
Post by ramza »
yes, i've done the 2nd method
and yes, now it worked!!
damn, you're fast and good!! :)
thanks once again!! :)
