double click tabs to close
ramza
Post by ramza »
double click tabs to close or rename would be cool
You can close a document by dragging its button outside the Document Bar area.
Please click here for details.
To "rename" a document, just save it under a different name. Press F12 to display the Save Document As... dialog, or choose the File | Save As... menu command. Type the desired name for your document, and press Enter.
ramza
right
Post by ramza »
thanks, that will do!
