Templates with Headers and Footer
communication
Post by communication »
Hi!
I want to create a special Template:
In the header the page number and in the footer name and e-mail adress.
Is this possible in Atlantis?
Everytime I try is, Atlantis creates a Template, but without header and footer :(
Try double-clicking the original document main window (outside the header or footer areas) before saving it as a template (File | Save Special > Save As Template...)
In other words, don't save with the Header or Footer areas still displaying.
Hope this helps.
communication
@Robert: thanks for the quick and brilliant tip! :idea:
This was the solution of my problem!
There is a glitch with the "Save as template" command of Atlantis. It will not save the header unless you switch to the main text of your document. A fix will be included in any next release of Atlantis Word Processor. We apologize for the inconvenience. Thanks for reporting this.
