Hot to insert Smiliies?
communication
Post by communication »
Hi!
Is it possible, to insert smilies in a text like :-) or :-( or ;-(
I want to do this with the letters, not with a picture.
Insert to where? If you want to disable graphic smileys ("emotions") in your forum posts, just check the "Disable Smilies" box before making a post. You can find this box below your message text.
communication
admin wrote:Insert to where?
In an *.rtf text, written with Atlantis Word Processor.
As you might know, Atlantis has a collection of clips. The standard clip collection (or Clip Library) includes 4 smileys. Any clip (including those smileys) can be inserted in your Atlantis document through the keyboard. If you type "*smi" in your document, Atlantis would display a popup list of the clips whose filename begins with "smi". You could easily choose the desired smiley from this list. But clips can be inserted to a document as-you-type only when the "Replace clip names As-You-Type" option in the "Clip Library Option" dialog is checked. To display this dialog, please click the Image button at the bottom of the Clip Library panel. Please click here for details.
communication
thanks for the quick help!!!!
