Error while updating
Andremusic
Post by Andremusic »
I noticed that there is a minor update and Atlantis is trying to get it by closing the program first. But nothing happens after that and when I start Atlantis again, it finds again that same minor update.A bug?
André
Keep on Writing!
Hi André,
It would help if you looked at the “Help | About...” dialog and told us which version you have, and which upgrade you are invited to install.
As you know, “Atlantis 2.0” does not exist yet… :?
Andremusic
Atlantis says it's the 1.6.4.0 version, the update says it's a 1.6.4.1 version.
2.0... yes, I put it there long time ago, funny that almost nobody noticed it. :)
Keep on Writing!
Andremusic
Andremusic wrote:Atlantis says it's the 1.6.4.0 version, the update says it's a 1.6.4.1 version.
btw. the update message says that it is released on 6/13/2006
Keep on Writing!
Maybe the problem is caused by your antivirus/firewall. It might be preventing the setup of Atlantis from starting.
In such cases, please just download the standard setup file of Atlantis from our site:
http://www.AtlantisWordProcessor.com/en/downloads.htm
and run it to upgrade your copy of Atlantis.
