greek in ''find'' dialog
I am using the registered version of Atlantis on windows 7, greek language, but with english menus. In the ''find'' dialog I can't insert greek characters (atlantis1.jpg). In version 1.6.4.1 the greek characters were ''ok''. I didn't notice from wich version exactly this problem begun.
- atlantis1.jpg (66.25 KiB) Viewed 8792 times
This has nothing to do with the Atlantis version. From what I see on your above screen capture, you have a heavily nonstandard Windows theme and display settings. Something is wrong with the default font for visual controls in dialogs. Possibly you need to add support for the Greek language to the Regional settings of your Windows.
When I paste Greek text to the Find/Replace dialog of Atlantis, it displays correctly:
- Greek.png (18.05 KiB) Viewed 8779 times
1. ''heavily nonstandard Windows theme and display settings''?? It's the windows ''classic theme, what's more ''standard'' than that?
2. Yes, me too when I paste Greek text to the Find/Replace dialog of Atlantis, it displays correctly, not when I type it.
3. Support for the Greek language to the Regional settings of Windows is ok too.
With all the same settings in windows, when I install Atlantis version 1.6.4.1 it works ok...
Under the "Windows Classic" theme, the GUI of Atlantis looks in this way:
I thought that you had "wrong" fonts for GUI elements.
But the glitch with the Greek text has nothing to do with your Windows theme. You are right: typing in the Find/Replace dialog does not work correctly. It is a bug in Atlantis 1.6.5. It has been already fixed in the latest beta version of Atlantis. You can download it from the Betatesting page. Thanks.
