Has something changed vis-a-vis oulining in the latest update? When I place the cursor at the end of an outline element and hit return, Atlantis used to add a new ouline element below it.
Now when I hit return at the end of a line, it breaks out of the outline format and goes to the margin.
What's going on?
This is a pain for me, 'cause the main reason I use Atlantis is for its outlining capability.
Thanks!
(File attached.)
Outlining Behavior?
Outlining Behavior?
- Cal_112.rtf
- (13.96 KiB) Downloaded 754 times
Thanks for the file.
The "Next paragraph style" property of the "Level 2" style in your document is "Normal". This is why Atlantis applies the "Normal" style to a new paragraph when you place the caret at the end of a "Level 2" paragraph, and press the Enter key.
Please choose the "Format | Style..." menu command of Atlantis, click the "Level 2" style, then click the "Modify..." button. Choose "Level 2" from the "Next paragraph style" box, and OK out of the open dialogs.
