ALT key
olddicedealer
ALT key
Post by olddicedealer »
I just registered Atlantis and love it, but I do have an odd problem: After assigning ALT-key combinations to various styles for scriptwriting, I find that they only work with the left ALT key. The right ALT key is dead.
Obviously, I can work around this, but it would be much better if both ALT keys worked.
By the way, both ALT keys work for the pull down menus.
Right, the Alt+<key> command shortcuts work in Atlantis only if you press the left Alt key. They will not work if you press the right Alt key. It is a limitation of the present version of Atlantis. Regrettably I cannot say when it will be lifted.
olddicedealer
Alt Keys
Thanks for the quick reply.
The ALT key issue is hardly a deal-breaker. I still think your word processor is the best program of its kind since Eric Meyer's VDE for DOS and I'm glad I registered. $35 is a bargain.
