The new version of Atlantis is great, I appreciate the effort you made fixing a couple things.
One more little thing, though--I would love to have the time of day on the status bar. I don't want to work through lunch or miss my martini.
Time on status bar
mhender668
TClock
There used to be an application called BarClock that showed time and date in the title bar of the active window. I have not been able to find it now, but you can try to google «barclock».
I prefer TClock – whick I have used for years. It is a taskbar clock replacement which is highly customisable, includes alarm and cuckoo clock – and it it free. You can download it from http://homepage1.nifty.com/kazubon/tclo ... index.html
- This is what it looks like on my computer. I never miss lunch.
- tclock.jpg (18.9 KiB) Viewed 13544 times
mhender668
Maybe this helps:
Make a clip "aaatime" :
insert
field
choose 'current time'
select 'show preview'
font 48 pp
You should have clip folders on
And you will see the up-to-date-and-time time.
See the printscreen.
Greetings.
Vincent
insert
field
font 48 pp
Greetings.
Vincent
- time in AWP.rtf
- (50 KiB) Downloaded 1176 times
Vincent van Gool, Amsterdam
