How to clear text formatting in Atlantis?
purcelljf
Post by purcelljf »
Is there a button that I can add to the tool bar that would allow me to take a selection of text, highlight, and remove the formatting?
Right now I sometimes have to copy the text and then paste it as text followed by the reapplication of a style. In Microsoft Word they have a "clear formatting" button so I want to know if there is anything similar.
Thanks.
Have you tried applying “Ctrl+Space” to the selection?
purcelljf
Post by purcelljf »
No I hadn't tried that but I like the results I am seeing using it.
Thank you much.
You can use the "Reset font format" (Image, or Ctrl+Space) and "Reset paragraph format" (Image, or Ctrl+Q) commands of Atlantis. They format a selection in the document according to the font / paragraph formatting of the paragraph styles associated with the selected paragraphs.
andygrunt
Post by andygrunt »
I may well have the wrong end of the stick regarding what you’re trying to do but have you also tried pasting your text in using ‘Paste as environment’ (Ctrl+Alt+Ins)?
purcelljf
Post by purcelljf »
Funny you should ask. Just before Robert and Admin had given me their answers I had tried using that as well. I always saw that choice when I used the right mouse button, but it sounded so weird that I never tried it before. Instead I would do the "paste special" from the top line menu and select "text".
There is a faster way to "paste special > plain text". You can click the "down" arrow attached to the "Paste" toolbar button, and choose the "Plain Text" command:
olstykke
Feature request
Post by olstykke »
I am rather new to Atlantis, but I like it.
I am having a problem and I am not sure how to approach it.
I want to copy and paste from another document into Atlantis.
I cannot get Atlantis to remove the "hard returns". Is there some way to do this/ add this?
Copy and paste are done in Atlantis just like in any other software: "Ctrl+C", then "Ctrl+V".
Here is how to remove the hard returns:
1. Select the target text.
2. Press "Ctrl+Shift+U", or use the dedicated toolbar button: Image
If this button is not already on your toolbars, you can put it this way:
1. Click "Tools | Toolbars..."
2. In the Toolbars dialog, select "All Commands" in the "Categories" drop-down on the left.
3. Click in the commands box under the "Categories" caption.
4. Type "j" on your keyboard.
5. The "Join paragraphs" icon should appear in the window unless it is already placed on the toolbar selected on the right.
6. Use the double-arrows buttons to place the selected button on the toolbar selected on the right.
7. OK out of the dialog to validate your changes.
olstykke
Post by olstykke »
Thanks, CRTL-Shift-U is working.
