I have just had to re-install Atlantis after a hard disk failure. I am now looking for a way that I can save my customisations of Atlantis including menu settings. I understand how to keep copies of my modified templates but I would also like to keep other settings (just in case).
Regards,
Peter
There is nothing more difficult to take in hand, more perilous to conduct, or more uncertain in its success, than to take the lead in the introduction of a new order of things -- Niccolo Machiavelli, The Prince, ch. 6
Hi Peter,
Tools | Options… > Save to File… button.
To restore the saved settings:
Tools | Options… > Load from File… button. Simply point Atlantis to the previously saved “Atlantis.ini”.
