File associations
Sentosa
File associations
Post by Sentosa »
File associations are not available with Atlantis installed on a removable drive?
Why?
From my point of view, that makes installation on a removable drive unworkable.
Serious rethink needed here guys.
A portable copy of Atlantis is supposed to leave no traces on the host PC, and make no changes to the registry of the host PC. By associating a portable copy of Atlantis with a file extension, you do make a change to the host system.
You do not necessarily need to associate Atlantis with any file extension on the host PC. You can easily open any document in Atlantis with drag & drop, or through the "File | Open..." command of Atlantis.
File associations can be made to work with Atlantis when it is installed on a removable drive. For this, you need a third-party utility called “eXpresso”. You’ll find it at http://gluxon.com/apps/eXpresso. The direct download link is http://gluxon.com/files/apps/eXpresso/e ... .1.paf.exe. Install this utility on your removable drive. Note that you might have to adjust the double-click capture if necessary. You might also have to manually enter the file extensions and the application that should open the corresponding files (in our case, “Atlantis.exe” of course).
When the associations are made within “eXpresso”, the files automatically open in the associated application, i.e. in Atlantis.
