insert/overwrite mode
MyLittleAmunRa
Post by MyLittleAmunRa »
Several times now, the insert/overwrite mode in Atlantis has changed from insert to overwrite without me changing it myself. When this first happened, I thought that perhaps I had pressed the wrong key or something. But that doesn't seem to be the case. Every now and again, Atlantis switches from insert to overwrite mode. All I can say is that this happens mostly immediately after a cut-and-paste operation.
Could you provide the step-by-step instructions for us to reproduce the problem?
By the way, did you know that you can switch the "Insert/Overwrite" mode by double-clicking the corresponding section of the Atlantis status bar?
