Replacing straight quotes with curly quotes
Sentosa
Post by Sentosa »
I have a novel with includes in excess of 100,000 beginning and ending straight quotes.
A publisher is interested in the novel, but has requested I change the quote style to smart or curly quotes.
I've tried every technique I can think of, but none worked. I'm somewhat reluctant to manually change these. :cry:
Has anyone found a way to do this?
Sentosa
Post by Sentosa »
Tried a different approach and it worked.
The easiest way to do this is through “Tools | AutoCorrect…”
Atlantis will offer to replace “straight” with “curly” quotes.
Sentosa
Post by Sentosa »
I find that works with new documents, but not with existing docs.
Atlantis has 2 modes of AutoCorrect:
A. AutoCorrect AS-YOU-TYPE
B. AutoCorrect AFTER-YOU-TYPE
AutoCorrect AS-YOU-TYPE works automatically when the “Autocorrect as you type” box is checked in the “Tools | AutoCorrect Options…” dialog.
AutoCorrect AFTER-YOU-TYPE applies only if you run the “Tools | Autocorrect” command.
As the names indicate, AutoCorrect AS-YOU-TYPE works as you edit documents, old or new; AutoCorrect AFTER-YOU-TYPE works only on already created documents.
