Email for help
fbailey
Email for help
Post by fbailey »
When i need help Atlantis prepares an email message using OE. I am on AOL and therefor cant send email on OE. What gives?
Atlantis does not use MS OE directly. Atlantis uses the "default Simple MAPI client" of your Windows. If you would like to use another email client with Atlantis, it should support "Simple MAPI", and should be configured as the "default Simple MAPI client" of your Windows (please refer to the documentation of your email client).
