Ability to square text to image
wildchild1954
Post by wildchild1954 »
A really nice feature to add to Atlantis would be the ability to square text to an image. I know it can be done using the tweak_epub utility but that can be a very long-drawn out process depending on the size of the file I'm working with. When squaring text in other word processors you can adjust the image position horizontally and vertically so it doesn't end up like the attached photo. In that the text is too close to the image and and there is too much blank space below it. So as you can see using Tweak doesn't give the most pleasing result like an actual text squaring would.
