Hi -- Recently Atlantis began to open with a big 3 line toolbar at the top. Graphic attached. Lots of icons. If I want to disable this feature, how might I do it?
Thanks,
JT
big toolbar
big toolbar
- the big toolbar
- big.toolbar.atlantis.jpg (101.13 KiB) Viewed 5803 times
Regards,
Jeff
Jeff
You can choose the "View | Toolbars | Hide" or "View | Toolbars | Autohide" menu command.
You can also downgrade to a previous version:
http://www.atlantiswordprocessor.com/en ... rsions.htm
toolbar choices
Thanks, saw that, and wondered where granularity went, letting you choose display of toolbars.
It was a version upgrade then?
Guess I'll use autohide.
Regards,
Jeff
Jeff
Re: toolbar choices
Yes, it was:jsthomas wrote:It was a version upgrade then?
http://www.atlantiswordprocessor.com/en ... _0_000.htm
