Extra line above inserted table
Csiga
Post by Csiga »
I run into the following problem using the latest Atlantis. On the first page of a document I create a table (I need this as a header for my documents). I select and copy it. After some text on my page I insert a page break and paste the table - on the new page an extra line is created above the table which I can not delete. Can you help me on this one? Screenshot attached.
A "page break" character cannot be immediately followed by a table. In your document, the "page break" is followed by a "paragraph end mark". If you check the "View | Special Symbols" menu command, the "page break" and the following "paragraph end mark" would become visible.
You can remove that page break, then click any paragraph of the first row of the table, then choose the "Format | Paragraph..." menu command, and check the "Page break before" box on the "Line & Page Breaks" tab.
