Is version 2 compatible with version 3
centurian
Post by centurian »
Hi
I updated my copy of Atlantis this afternoon (Thursday 26) to V.3.2.1 and I'm happy with the result.
I also have version 2 on my Mini laptop for when I'm traveling. Is the version 2 compatible with the version 3 on my desktop. Because if it isnt then I'll have to write everything in notepad and transfer it when I get home. A bit tediouse, but it will have to do.
Thanks a lot.
Any document created with version 2.x, can be edited with version 3.x. And vice versa. But if your document contains an index, you should not edit it with version 2.x.
centurian
More than one computer
Post by centurian »
Hi
Thanks for your reply regarding compatability between v2 & v3.
I'd like to know if I can have Atlantis running on more than one computer.
Thanks a lot.
Michael
Re: More than one computer
centurian wrote:I'd like to know if I can have Atlantis running on more than one computer.
Yes, you can.
