Please build in to the software a check box for Updates.
357mag
Post by 357mag »
What I've noticed that Atlantis does is after the program has been on your computer for awhile when you close out of it you will see a dialog box come up that asks you if you want to update the program.
This I don't like because when I load my computer with a fresh install of Windows I get everything set up exactly the way I want.
And I rarely download any updates.
There should be a checkbox in Options built-in to the program already that the user can check if he wants Updates.
Instead of this dialog box that presents itself three weeks after you have had it installed.
Just uncheck the "Remind me to check for updates ..." box in the "Help | Check for Updates..." dialog of Atlantis.
