eBook from multiple files
DaleDe
Post by DaleDe »
It would be nice if I could make a single ePub book from multiple source files. It would be ok if they all needed to have the same template (CSS data). The idea is just to mange a book using independent files for each chapter.
You can easily merge multiple document files into one (temporary) document, then convert it to eBook. Just create a new document, then insert the "chapter" files through "Insert | File..." menu command, or drag & drop the "chapter" files from the file manager to that temporary document. You can insert multiple files at once.
