Help File
writenow
Help File
Post by writenow »
I am using an older version of Atlantis 1.6.6.5. Before I "upgraded" to this version, a wonderful help file came with the word processor. I was hoping to be able to go back to the earlier version, but I can't find it. Is there a place I can download an earlier version?
I personally do not think that having the Help articles offline is more important than having all the new features, improvements and fixes of the latest version of Atlantis.
Anyway, you can download the setup files of older versions of Atlantis here:
http://www.atlantiswordprocessor.com/en ... rsions.htm
writenow
Earliest version is 1.6.6.5?
Post by writenow »
:) Yes, it is obvious you do not think having the Help files offline is important. Still, I do, and I appreciate you pointing me to earlier versions. Trouble is, the version 1.6.6.5, the earliest version on the link you provided does not include the Help file. I lost the Help file when I "upgraded" to this version.
You can try downloading from this site.
writenow
Just Found
Post by writenow »
I only just now found your answer. Thank you so much for the link. I downloaded the file.
I do, however, have another question, but it is unrelated so I will start a new thread.
Thanks again.
