Select headings in Control Board
JPh1
Post by JPh1 »
When Find is performed using a heading style format, it would be useful to select the corresponding headings in the Control Board. That way, the body text under those headings can be selected as well, and the fragments can be copied to clipboard or used to create a Selection.
The next release of Atlantis Word Processor will have a new feature "Collapsible headings":
http://www.atlantiswordprocessor.com/en ... adings.htm
When the required headings are selected in the document, you could right-click the selection, and choose the "Headings | Collapse" command. Then simply press Ctrl+C.
