Cut lines for 2-up A5 doc on A4 paper?
rjbull
Post by rjbull »
Please bear with me, I'm only an occasional user of Atlantis...
I have a short text that fits comfortably on A5 paper, but I need several copies. Most printers have A4 paper, so I can print 2-up. Is there any way of adding fiducial marks, both on-screen and on the paper, to show the centre line for cutting the A4 neatly into two A5? A bit like the "cut lines" for booklet printing, which I haven't used but saw in Help?
Thanks...
rjbull
Re: Cut lines for 2-up A5 doc on A4 paper?
Post by rjbull »
Uh, supplementary question.
To do the printing as described, I have to bring up the Print dialog, set Number of copies, Pages per sheet, and Actual paper size. If I go back to editing, then try printing again, they have all reverted to default. Is there a way to associate a particular printer set-up with a given document?
Thanks.
There is no way, sorry.
SilverCookieDust
Post by SilverCookieDust »
Possible workaround: set your document page to A4 landscape, copy/paste two lots of your text and divide it into two columns, and in the column dialogue box tick the "Line between" option. This'll put a line midway down the page that you can cut along once printed.
