Comment/Uncomment
wood.22mark
Comment/Uncomment
Post by wood.22mark »
Is there a way to include notes in a mass of text that won't print? Margin notes? Editorial marks?
When programming I can include text between [comment] and [uncomment] and the program ignores it. Does AWP have a similar feature? I considered using white font on a white background but that shows up as blank space and I would like to avoid that. I also considered asterisks or superscript numbers with footnotes in the footer but those also must be removed by hand or they show up when printed.
Ideally, I could choose to print text with comments visible or with comments ignored while print-formatting.
Thank you for your time. If the answer is no, I will resubmit this as a feature request.
Re: Comment/Uncomment
The current version does not support the comments. As a workaround, if a comment is short, you could add a bookmark instead, and use the comment as the bookmark's name.
wood.22mark
Thank you!
