Menu bars too small
lynneconnolly
Menu bars too small
Post by lynneconnolly »
I recently got a new computer with a 4k monitor. When I open Atlantis, the menu bars and status bars are really small. I can change the size of the buttons fine, but not these. Is there any way of doing it so I can, you know, actually see them and use them?
Lynne Connolly
lynneconnolly
Re: can't restore from ini file
I can do that part now!
Lynne Connolly
Re: Menu bars too small
OK, but what was the problem? And the solution?
lynneconnolly
I had to change all the magnification through the Windows app, rather than through Atlantis. It's tricky to get the right balance, and there's a program called Windows Aero where you can do it with more accuracy.
Lynne Connolly
