I have been trying to use search-replace to find the end of sentences in order to break apart paragraphs into sentences each on its own line. I was hoping to use regex (at which I am a beginner).
The following regex string works in Libreoffice Writer but does not work in Atlantis:
([.|?|!|(.”)|(.’)|(?”)|(?’)|(!”)|(!’)])\s
The replace string is : $1\n
In Atlantis, you?” becomes you? ¶ ” (with ¶ being the end of a line - the line ends with the question mark and the next line has the quotation mark by itself). see attachment
Is there already a code - similar to ^p - but to find sentences instead? If not, what is wrong with my regex?
Thanks.
how to find end-of-sentence in search-replace?
kenfhill84083
- Atlantis _ regex to find sentences.png (1.88 KiB) Viewed 8330 times
Re: how to find end-of-sentence in search-replace?
If you want to replace the white space between sentences with something, you can search for the following pattern:
It matches the white space itself.
Code: Select all
[\!\?.]"{0,}|^w|-
kenfhill84083
Thanks. Is there a detailed repository for these kinds of regex snippets?
There is no repository per se. But please see the following Help articles:
https://www.atlantiswordprocessor.com/en/help/regex.htm
https://www.atlantiswordprocessor.com/e ... _email.htm
If you need help with regular expressions, just ask.
kenfhill84083
Thanks for the response and the invitation. The responses here are very helpful.admin wrote: Sat Jun 24, 2023 4:53 pm There is no repository per se. But please see the following Help articles:
