stripping hyperlinks from a document
kenfhill84083
Post by kenfhill84083 »
I often paste text from an application that embeds hyperlinks that work in their app but are retained when pasting into Atlantis, where they do nothing but display useless tooltips.
I have been looking for an easy way to strip them out of Atlantis documents. I don't want to use plain text because I want to retain formatting.
Any suggestions?
Thanks.
Re: stripping hyperlinks from a document
Press Ctrl+A to "select all". If the selection contains hyperlinks, Atlantis would display the "Hyperlink" context toolbar. Click the "Deactivate hyperlink" Image button.
kenfhill84083
Thanks.
