feature request : Find-Replace : tab order should include search options button
kenfhill84083
Post by kenfhill84083 »
It would help me if the Find-Replace tab order included the "search options" button which I use a lot for saved searches. Because I use it a lot I have to continually take my hand off the keyboard, grab the mouse, guide the mouse to the tiny button, and click it. I am not a very skilled mouse user so I waste lots of time on these detours.
Thanks.
Re: feature request : Find-Replace : tab order should include search options button
Uncommon commands are not supposed to be one-click-away.
The “Settings” button of the “Find/Replace” panel of the Control Board is not “focusable” (cannot be included in the tab order), and you currently cannot assign keyboard shortcuts to the commands of the Control Board panels.
Atlantis will soon probably have the “batch find & replace” feature.
