Daily word target
Eduardo
Daily word target
Post by Eduardo »
Atlantis is getting better and better with each update. Thank you very much for your continued efforts.
I was wondering if it would be possible to implement the Daily word target in the Status Bar, beside the Writing target or within it.
Please consider it.
Thank you.
Eduardo
Re: Daily word target
I think that adding a new feature and a new status bar section that is very similar to another existing feature is not a good idea. You can simply activate the current writing target feature at the start of your working day. This is just a couple of mouse clicks.
