Putting text inside floating pictures (AtlanTip)
JPh1
Post by JPh1 »
Curious to experiment with the text inside a picture tip, I downloaded the example file "Text inside pictures.docx". But when displayed in AWP, text is around the picture, not inside, even though Wrap points are correctly located and the wrapping style is Through. I'm using version 4.3.10.3.
Re: Putting text inside floating pictures (AtlanTip)
I suppose you need to switch to the Print Layout view.
JPh1
Post by JPh1 »
That simple indeed...
