Dark Mode theme tweak
ckent
Post by ckent »
Returned to Atlantis Word Processor after some years away, and appreciating Dark Mode, but it would be good if the drop down boxes for "Style", "Font" and "Font Size" would also change their style in Dark Mode so the colors are inverted (white text on a black background). Currently, having the white drop down boxes is a little distracting in Dark Mode.
Atlantis Dark Mode.jpg (89.78 KiB) Viewed 7872 times
Re: Dark Mode theme tweak
This will be changed in the next build of Atlantis. Thanks.
ckent
Post by ckent »
Thanks! If you're making Dark Mode theme tweaks, I would also point out darkening the background behind the document windows. I find it to be too bright when working at night. Perhaps it could be the same color as the windowed document background?
Screenshot 2025-11-24 125240.jpg (114.53 KiB) Viewed 7670 times
Will be changed too. Thanks.
ckent
Post by ckent »
I noticed that in Dark Mode if I press F9 to go to full screen, and then press F9 again to return to windowed mode, the Title Bar loses its Dark Mode color.
I can reproduce this too. This will be fixed in the next build. Thank you!
