'Select' Fixes
dec
'Select' Fixes
Post by dec »
One of the very few things about Atlantis WP i can find to fault is that i cannot -
- Select Page
- Print Page
- Print Selected.
Re: 'Select' Fixes
1. You can select the current page in the active document by pressing Ctrl+K, G.
2. and 3. There are corresponding options in the "File | Print..." dialog of Atlantis:
