Small bug in Text Cursor Options setting window
ckent
Post by ckent »
A small bug: there is a case where the Cursor is not visible in the Preview window of the Text Cursor Options settings; if the Windows setting for Cursor Blink Rate set to "None" (so it's a solid non-blinking cursor) in the Keyboard settings found in Control Panel. The cursor is still visible in the document window as expected. I'm using v 5.0.0.10
Screenshot 2025-11-24 131936.jpg (56.71 KiB) Viewed 4809 times
Re: Small bug in Text Cursor Options setting window
Will be fixed in the next build. Thank you for paying attention to such details.
