Language Setting Error
dec
Post by dec »
will not change language from US English, although it allows selection of AU English under 'default' which seems to not ha
ATLANTIS-DEFAULT-LANGUAGE-ERROR-27-11-2025 20-27-07.png (30.46 KiB) Viewed 4785 times
ATLANTIS-DEFAULT-LANGUAGE-ERROR-1-27-11-2025 20-27-07.png (16.46 KiB) Viewed 4785 times
ve the slightest effect.
see attached
Re: Language Setting Error
You usually need to make a text selection in your document before choosing the “Tools | Language…” menu command.
The “Tools | Default Language…” command doesn’t change language of the existing document text.
