Permanently delete Styles
wildchild1954
Post by wildchild1954 »
I've been using Atlantis almost since it came out and I have a lot of Styles that I no longer use. However, every time I open a new document every single Style I have ever used comes up and has to be deleted one-by-one. Is there any way to permanently delete these unnecessary and unneeded Styles? I am using Atlantis version 4.4.2.0 and I have attached a screen shot showing a lot of the unused Styles. Not a one of these have been used in over 5 years now.
Re: Permanently delete Styles
Each document in Atlantis has its own set of styles.
When you create a new document in Atlantis, it contains all the styles present in the corresponding default document template. By default, there are only four styles in the "Normal" template of Atlantis.
The Reveal formatting tool of Atlantis has a command to delete all unused styles:
wildchild1954
Thank you very, very much!! That solved my problem!! :)
