Convert option Insert Footnote/Endnote grayed out
gentje
Post by gentje »
I'd like to convert Endnotes to Footnotes in a document. When I follow the instructions in the Help, the Convert option is grayed out. Why? I've tried every which way, but no matter where I place my cursor, the option isn't available.
Screenshots below.
User error, I'm sure, but still frustrating. Thanks!
Re: Convert option Insert Footnote/Endnote grayed out
This button is grayed out when there are no footnotes/endnotes in the active document.
gentje
Post by gentje »
And yet, there are definitely endnotes in this document!
Can you email your document file to support@atlantiswordprocessor.com?
gentje
Post by gentje »
Yes - I will do that this morning. Thanks!
Thanks for the files. There are no footnotes or endnotes in your documents.
