add auto hide option for control board
nluclat2025
Post by nluclat2025 »
Dear sir,
To make better visibility of entire document make the control baord auto hide option controlboard/settings/add autohide option
the earlier request of drag and drop to add new snipped into clip libary was not resolved yet which is most important for every one of the users
Re: add auto hide option for control board
In Atlantis, the autohide is reserved for the toolbars.
Please don’t make baseless claims and state your personal opinion as fact.
nluclat2025
Hi Sir,
1. There is the F6 shortcut to open and close the control board but i am unable to find the auto hide option
2. To insert the snip drag and drop option is very crucial which is no wher availble so far even in the ms office latest
3. clip folders and clips in control board can not be resizeble verically it creates a convergent look when the snippets count becomes more for searching
4. If you could provide the global serach option/icon just beside the clips header text to search the text from the snipets text withauto filter is more useful when snips count becomes more to catch the required text
5. Create an interface like the image attatched here which seems good for better visibility that History indicates the copied snip text, nextone are the separate database groups
Your hardened efforts are appriciated and expect further developments at earliest
Thank you
Regards
Kiran Kumar
Screenshot 2026-03-11 004138.png (6.54 KiB) Viewed 14750 times
