After updating to 5.0.5.0 and closing down, re-opening shows all documents have lost their font colors, all are white-on-white colors on all documents. Closing down 5.0.5.0 and re-opening does not help, and looking into some documents, the Styles have empty Font Color fields. Re-Installing 5.0.5.0 does not help.
Right now this is happening on Windows 7 SP1 level machines and I will check Friday morning MST time on my Windows 11 Pro machines.
I might retrograde and back down to the last installed version, yet I hope that the Atlantis.ini file has not been somehow "damaged" or something in 5.0.5.0. re-work has gone bonkers.
Have never seen this situation or problem in past AWP Upgrades or versions, major or minor.
Joe Rotello (josephrot@yahoo.com U.S.: +1 865-867-8237)
Facebook: https://www.facebook.com/joseph.rotello.1
5.0.5.0. font / text color whiteout
JosephRot2
Re: 5.0.5.0. font / text color whiteout
Updating from what version?After updating to 5.0.5.0
Can you email one of your "white-on-white" documents to support@atlantiswordprocessor.com?all documents have lost their font colors, all are white-on-white colors
JosephRot2
Will do. Have to wait until early morning MST Saturday, yet I will deep test the Windows 11 machines as well, and email you a sample file or two from both the Windows 7 SP-1 and the Windows 11 with the latest Windows 11 Update on it.
Upgrades have faithfully followed all the AWP progressions, so I updated both the Windows 7 SP1 and the AWP in use on the Windows 11 machine from the AWP version immediately prior to 5.0.5.0, which was version 5.0.4.1 as I recall. 5.0.4.1 looked and worked great as expected especially on the Windows 7 SP-1 machine.
Joe Rotello (josephrot@yahoo.com) U.S.: +1 865-867-8237)
