Save Picture
Guest
Save Picture
Post by Guest »
How do I save a picture from the net and open it up in AOM. I have tried save and save as but it will not open up in Atlantis. :?:
BuffyBot
Post by BuffyBot »
If you want Atlantis to open up all jpeg files then hold down the Shift key while you right-click on any jpeg. Then choose Open with.... Choose Atlantis to open the file and make sure you place a check the box that reads "Always use this program to open this type of file".
Then Atlantis will be the default handler for jpegs.
BuffyBot
Post by BuffyBot »
If you don't want to associate jpegs or images with Atlantis directly, then you could try this instead:
Create a shortcut to Atlantis and place it in the "Windows\Send To" folder. Then any time you download a jpeg, you can right-click on it, select "Send To", and send the image right to Atlantis.
You can right-click any picture in your Web browser, then choose "Copy" from the right-click menu, then use the "Edit | Paste" command in Atlantis.
Alternatively you can right-click any picture in your Web browser, then choose "Save Picture As" from the right-click menu, then use the "Insert | Picture" command of Atlantis. You could also drag & drop any picture from Windows Explorer to Atlantis.
You could also click the "Clippy Bank collects clipboard data" toolbar button (by default it is a part of the Alternative set of toolbar commands - you might need to press Ctrl twice to switch toolbars, and access this toolbar command). When the "Clippy Bank collects clipboard data" toolbar button is checked, any image placed on the clipboard, would be also automatically appended to the Clippy Bank of Atlantis. You could view the Clippy Bank in Atlantis by pressing F8. You could open the desired Web page(s) in your Wen browser, then simply right-click the desired images, and simply choose "Copy". All the right-clicked images would be automatically appended to the Clippy Bank.
1953
Guest
Post by 1953 »
Is there a way to right click on an image in the web browser and (send to ) Atlantis :?: as send to in windows. :?:
