Favorites - thankyou/+
Shanforest
Post by Shanforest »
Thank you so much for the Favorites facility (I was one who requested it so I am absolutely deliughted)
I am sorry to ask for a little more when you have done so much, but I would like the Favorites link as found under File, to be on the toolbar list.
That would mean I could open the dropdown menu straight off the toolbar, displaying Add, Organise, and the list I have selected.
For frequent fast use, a link sequence going through 1 File dropdown/ 2 Favorites dropdown/ 3 select item is not direct enough: three clicks instead of two. Also dropdown menus do slip about and disappear if there is more than one layer.
If it's just not possible it's still very good to have the current option.
Thanks again.
Shan UK
Shan of the Forest
The "Add to Favorites" toolbar button already has a drop-down menu with all the Favorites-related commands:
Shanforest
Whoops sorry
The buttons on offer were labelled "Add to Favorites" and "Organise Favorites" so I didnt realise they also gave the list of options.
It's a lovely item - using it every 5 minutes now!
Shan of the Forest
Max_Quordlepleen
Post by Max_Quordlepleen »
Thanks again.
Shan UK
Can it be mapped to a hotkey combo? If so, you may find that even faster.
Salaam alaikum, noho ora mai
Regrettably "the list of Favorite documents" cannot be associated with a hot key. But with the default main menu of Atlantis, you could press Alt+F,F for displaying the list of Favorites available in the main menu.
