Since the last update I can only page break using the keyboard (Ctrl+Enter) and can't column break at all.
Thank you SO much for the Favourites button. I made a doc today with all my usual signatures and snippets. Very usful Also I have telephone nos, bills, and lots of other frequent use data there now. Bliss.
Break column
The drop-down menu of the "Insert Symbol" toolbar button includes the "Column break" command. Also you could associate the "Insert Column Break" command with the desired hot key through the "Tools | Hot Keys" dialog. You could also place this command on your toolbars, or add it to your menus (Tools | Toolbars, Tools | Menus).
