File handling
clarkelec
File handling
Post by clarkelec »
Under File/Open, I can't delete files, and the response when I try is "access denied." However, I can delete the files through Windows (My Computer). Is there a file attribute problem, and if so, why can I delete them through windows?<br>Thank you,<br>Bob
Re: File handling
You cannot delete documents locked (opened) by Atlantis. You should close the desired document first. Then delete it.
steve
Re: File handling
Post by steve »
I can't seem to find a place to start a new thread on the main board...is something buggy with the software? I haven't been able to log on to rrsol for more than a week, have there been problems?<br><br>steve
Re: File handling
To start a new thread, click the New Thread (you can find this button in the black caption of the board).
clarkelec
Re: File handling
Post by clarkelec »
How can I change the opening default file folder and then make the new folder the default file folder. Thank you ???
Re: File handling
Use the "Document Folder" option of Atlantis. Choose the "Tools &#124; Options...", click the "Load / Save" tab.
