Problem with c3
BuffyBot
Problem with c3
Post by BuffyBot »
Every time I try using the latest (c3 beta) Atlantis stops responding after I type 3 characters in a newly created document. No error messages-- it just freezes.
I reinstalled the (c2) and everything works as it should.
Tried the (c3) again and encountered the same problem.
Win98 FE
BuffyBot
Post by BuffyBot »
This happens right after launching Atlantis-- when it creates a new document at startup. It doesn't happen when I launch an established document.
This time there were some error messages:
1. Access violation at address 00401B9D in module Atlantis.exe. Write of address 80000004
2. Accress violation 00401E75 read of address FFFFFFFF
3. External Exception C000001D
Max_Quordlepleen
Post by Max_Quordlepleen »
I can confirm this problem, although on my Windows 2000 installation it doesn't freeze, it just crashes, silently disappearing. As you say, existing documents are no problem.
Salaam alaikum, noho ora mai
Thanks for reporting this. Please download a newer build.
Max_Quordlepleen
admin wrote: Thanks for reporting this. Please download a newer build.
Thanks, that was fast! :D
