folder tabs at top representing each open document
zippytex29
Post by zippytex29 »
edit pad Pro has a very good feature. It has little folder-type tabs at the top of the screen that represent each open document. It is a very good feature. Please consider it. :wink:
Atlantis has the Document Bar with buttons representing each open document.
BuffyBot
Post by BuffyBot »
Another thing to consider is that Atlantis already uses a tabstrip across the bottom for bookmarks.
dosdan
Post by dosdan »
admin wrote: Atlantis has the Document Bar with buttons representing each open document.
This is OK if you habitually open multiple docs, but it does consume an extra line of the display. I prefer the Alt-1, Alt-2, Alt-3 etc. document-switching hotkeys.
dosdan
Post by dosdan »
You can specify a different position for your Document Bar. Simply right-click the Document Bar, and choose the "Position" command:
