Greetings!   Two questions
mgomgo
Post by mgomgo »
1: &nbsp;how can I make the vertical scroll bar on the right side of the page wider (like you can in Windows?)<br><br><br>2: &nbsp;I notice that when keeping a .cod file on a "virtual drive" &nbsp;(encrypted container) that I must re-enter the password each time I close the file. &nbsp;Is there a work-around? &nbsp;<br><br>By the way, Atlantis is a terrific program for me!
Re: Greetings!   Two questions
>how can I make the vertical scroll bar on the <br>>right side of the page wider (like you can in <br>>Windows?)<br><br>Regrettably this is not possible.<br><br>Atlantis asks for a password when you<br><br>a) create a new encrypted document,<br>b) open an existing encrypted document,<br>c) save an ecnrypted document under a new filename,<br><br>Maybe you simply performed one of the abobe operations? Any virtual drive should work in the same way as ordinary drives.
